can I change the local device name ?
Instead of rs, on one device to rs1 and on second device to rs4,
because I have 2 RShake devices in the same LAN, so I can search/connect local to both with “rs1.local” and “rs4.local”.
Thanks in advance,
Hans
Hello Hans, and welcome to our community!
When more than one Shake are connected to the same LAN, the first one is automatically renamed rs-1.local/
and the others become rs-2.local/
, rs-3.local/
, and so on. It is not possible, as of now, to manually rename this address.
In some instances, where this automatic assignment does not work, then the alternative way to reach the Shakes connected to your network is to use their IP addresses in place of rs.local/
