Hi guys:
I have confirmed an initial report that the CAPS server is down. Please take a look at your earliest convenience.
This is what I see in Swarm:
branden@branden-System-Product-Name:/opt$ swarm
2020-06-18 05:39:59 INFO - Swarm version/date: Version: 2.7.1 Built: 2017-05-22T16:56:57Z
2020-06-18 05:39:59 INFO - current directory: /opt/swarm-2.7.1
2020-06-18 05:39:59 INFO - user.home: /home/branden
2020-06-18 05:39:59 INFO - Using configuration file: Swarm.config
2020-06-18 05:39:59 INFO - java.version: 1.8.0_252
2020-06-18 05:39:59 INFO - maximum heap size: 1593.000 MB
2020-06-18 17:40:02: (WARNING) caps.raspberryshakedata.com:16022/connect() IOException: Connection refused (Connection refused)
2020-06-18 17:40:02: (WARNING) caps.raspberryshakedata.com:16022/connect(): giving up.
2020-06-18 17:40:03: (WARNING) caps.raspberryshakedata.com:16022/connect() IOException: Connection refused (Connection refused)
2020-06-18 17:40:03: (WARNING) caps.raspberryshakedata.com:16022/connect(): giving up.
java.lang.NullPointerException
at gov.usgs.net.InternetClient.writeString(InternetClient.java:74)
at gov.usgs.earthworm.WaveServer$2.attempt(WaveServer.java:92)
at gov.usgs.util.Retriable.go(Retriable.java:143)
at gov.usgs.earthworm.WaveServer.getMenuSCNL(WaveServer.java:106)
at gov.usgs.earthworm.WaveServer.getMenuSCNL(WaveServer.java:77)
at gov.usgs.volcanoes.swarm.data.WWSSource.getChannels(WWSSource.java:267)
at gov.usgs.volcanoes.swarm.chooser.DataChooser.openSource(DataChooser.java:760)
at gov.usgs.volcanoes.swarm.chooser.DataChooser.access$1700(DataChooser.java:99)
at gov.usgs.volcanoes.swarm.chooser.DataChooser$DataSourceOpener.construct(DataChooser.java:830)
at gov.usgs.volcanoes.swarm.SwingWorker$2.run(SwingWorker.java:108)
at java.lang.Thread.run(Thread.java:748)
2020-06-18 17:40:03: (WARNING) getMenuSCNL() IOException: null
2020-06-18 17:40:03: (INFO) Server returned menu:
2020-06-18 17:40:03: (INFO) null
2020-06-18 17:40:04: (WARNING) caps.raspberryshakedata.com:16022/connect() IOException: Connection refused (Connection refused)
2020-06-18 17:40:04: (WARNING) caps.raspberryshakedata.com:16022/connect(): giving up.
2020-06-18 17:40:04: (WARNING) getMenuSCNL() IOException: null
2020-06-18 17:40:04: (INFO) Server returned menu:
2020-06-18 17:40:04: (INFO) null
2020-06-18 17:40:04: (WARNING) WaveServer.getMenuSCNL(): giving up.
Yours, branden
