No trouble, and thank you for the complete logs from your Shake.
From what I can see, the Shake boots up without issues, but there are some issues, as you can see from this series of errors:
2026 110 15:06:28>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2026 110 15:06:28>> Data has been successfully received, fatal condition resolved.
2026 110 15:06:31>> internal error: buffer overflow! cannot process read data...
2026 110 15:06:31>> buf: {ÿOkøAA@Ma2?ÝÑ?E?AQÐE
2026 110 15:06:31>> y???U?Z]?ÄL]ª
The gibberish above, paired with buffer overflow and MCU errors, is usually a symptom of insufficient power supply, where the Shake cannot get enough power to either start or work properly.
Thus, in the end, I advise you to check whether the current power supply continues to deliver a stable voltage between 5.0 and 5.2V and a current of at least 2.5A at all times (3.0A if the Raspberry Pi board being used is an RPi4), as a decrease in power could lead to data service interruption.
With your long cable extension situation, and even though you didn’t see low voltage warnings in the logs, voltage drop over long distances can be the cause of what you are seeing:
- For such a long cable, you’ll need to check if you are getting enough power at its end (and eventually, calculate the wire gauge needed to minimize voltage loss over 60 meters)
- This is because an insufficient power supply can cause system instability without always triggering undervoltage warnings
Going on to the GPS Signal issues, even though your GPS had a lock initially, tree coverage can cause intermittent loss of satellite connection. Here’s what is likely happening:
- If the GPS module loses contact with satellites for too long and then regains connection, it returns to a locked state where the NTP daemon adjusts the computer clock accordingly
- This may result in time tears in the data, which, together with the possible power supply issues described above, could explain your fragmentation
- These time tears would be noted in
/opt/log/odf_SL_plugin.info in this form:
2026 113 04:47:14>> Time adjustment M0: HARD RESET. This will result in a one-time time-tear.
2026 113 04:47:16>> 5.0: NTP Time (Init): NTP: 1776919594.253725052
2026 113 04:47:17>> 5.2: NTP Sync (HARD): VEL Before: 1776919470.601999998 After: 1776919593.993000031 Diff: 123.391000032
To summarize:
- check if you are getting adequate power supply at the Shake, and maybe consider a small UPS that would help in regulating your power situation
- and then, as you can imagine and if you can, try to improve the GPS antenna positioning as much as possible
Let us know what you find out!
