my shake run long time, but then possible the sd card was full or broken and the shake don’t boot.
I have now, some month ago, recreate my shake and he is connected but not shown at the map.
Can you see from the logfiles what is possibly not yet correct or do you need to reset something because he was once online.
Thank you for your logs. It seems that there were some issues with the communication between the sensor and the blue Shake board, but they seem solved.
Sometimes it can take quite a while before the station is visualized on the map, or accessible via SWARM or other services, up to 24/48h. It seems, from the logs, that even if a server connection is established, there may be some issues, but we’ll look into them when this time period has passed.
It is an issue that we know of. I have opened a ticket for our software team to investigate what’s happening with MyShake, and I’ll get back to you as soon as I have news.
regarding this issue of not seeing streams/data on ShakeNet My Shake section, we have located the problem and it should be solved within the next day or two.
I will write here again to confirm that everything is back online. Be sure that no data is being lost.
