Means what? My end? Your end?
Hello kurt1000, just a bit more details to help you in a better way.
Is this happening when you are trying to connect to the Shake via the rs.local access? Is your shake connected directly to your pc/laptop or to a router?
For the router way, if you haven’t already done so, try to shut down the Shake, restart your router, then when the internet is on again, start up the Shake again. Can you access the rs.local front-end now?
If yes, could you please post the front-end logs from your Shake?
