I’m trying to connect my 4D (AM.R4F18) to the WiFi, but I’m having some issues.
On the WiFi page, it wouldn’t successfully test the WiFi password with my access point. I tried three different access points and it would all fail testing the WiFi password.
I thought it worked once and I hit “Save and Reboot”, but now when I try to check “Connect to WiFi”, I would get an error “Failed to turn on WiFi, please check your Raspberry Pi for hardware issues.”
Now it will only pop up that latter error if I try to check “Connect to WiFi”.
I’m still using an ethernet connection to it now, but in order to move it down to my garage, I need to go to WiFi.
Logs attached.
Edit: This is a Pi 4 Model B - 4GB RAM, but shows up as UNKNOWN device name on rs.local.
RSH.R4F18.2021-10-23T23_56_06.logs.tar (391.5 KB)
